Che tipo di batteria e' questa?
Ciao ADV,
Sto per montare lo sterling alternator to battery charger . e non so come settare il tipo di batteria....... Per i servizi ho una batteria 'sbagliata' (perche' per avviamento, ma e' nuova e regalata quindi la tengo Big Grin ) si tratta di questa fiamm .
mentre per il motore c'e' una gel.
Dalla kenixmarine mi hanno confermato che la carica della batteria motore e' molto piu' blanda quindi non ci sono problemi ad avere batterie di tipo diverso.
Secondo voi come devo impostare 'l'attrezzo' per ricaricare efficacemente la fiamm come batteria servizi??
Sotto sono riportati i tipi di batterie supportati dallo sterling:
1) {ie1 U.S. spec. l:loosi 14.0. Tine i - l0 hls, Float 11.7V
American gel manufactures want a different charging regime than the European ones. If in doubt ask the baftery supplier.
2) ÄGM U.S. spcc. Binst 1.tr.15!. |'iure 1 - 8 hrs. Floal l-1.l5v
This is the setting which most American AGM battery manufacturers would like. Ask your battery supplier for the gorrect setting as this is a new battery type which is becoming more and more popular.
3) Sealcd Lcad-Acid Bocst 14.:1V. Tirne I - l2 hrs, Float i3.6V
Sealed lead-acid batteries are simply lead-acid batterios which have no access to top up the water level.
4) Iluropean Gei ,r liriirle spcc. Boost t;tr.4i Jure 12 - ?4 hrs' Irltiat ll.8V This program is, as per the recommendation of Exide, set at a voltage of 14.4 volts for about 12-24hrs. The unit then drops to float voltage to maintainlhe batteries.
5) liuropeanAGM spec. I]oost 14.6V, l'inte I - 8 hrs, Float l-l.lV
This is what the European AGM suppliers such as Optima want for their
batteries. Again we would strongly recommend you contact your battery
supplier to confirm which charging option they require for their batteries. This higher voltage appears to be for AGM batteries with a highdr calcium content on the plates.
6) Open Lead-Acir1 Boost 14.8V Timc I - 8 trrs, Ploat l-1.3V
or sealed lead-acid batteries, where you can unscrew the lid ofthe battery and are able to top it up with water, The maximum boost voltage for this fype of batteries is 14.8V.
7) Calciunr-Calciurn (Jiqr-rid lead-acirl): tr]ocst l5.lV. Time 1 - 6l.rrs, Itloat 13.6V
Some modern batteries have had calcium added to their plates in order to reduce water loss in the battery. The down side with this is that you need a high charge voltage to get the batteries charged. This setting goes up as far as 15.1 volts on boost and can have a detrimental effect on voltage-senstive equipment on the
boat/vehicle. It is important to ensure that your equipment works safely at a voltage in the region of 15.4 volts (x2 lor 24V systems) before selecting this option, most equipment does but not all.
8) Ile-suiphatir:rr Selling: lloost LE.5!', Timc 4 hrs, Float none/otT.
WARNING: This is a very dangerous setting if used without understanding what it does. First of all, the batteries should be isolated lrom the boat's system as the voltage will be pushed up close to 16 volts which will damage some onboard equipment. The reason why you would engage this charge mode is to blast the
sulfation off old or unused batteries to regenerate them. It will probably need to be used on an old set olbatteries which are not charging or holding a charge.
This program will help a lot to remove the sulfation from the plates. It is
unlikely this setting would need to be used when the batteries are still new. Do not use this setting on sealed, gel or AGM batteries as they will gas and you will be unable to replace the water loss! DO NOT USE ON LIFEPO4 BATTERIES
9) LiFePO4 Lithium batteries, this is a charge of 14.8 volts and a {loat of I 3.8
Mi pare una normale batteria al piombo ad acido libero coi tappini dai quali puoi rabboccare acqua distillata.
Se così è, il programma Sterling adatto è il n. 6.
Se invece è sigillata (non si può rabboccare dai tappini) il programma è il n. 3.
Buona ricarica
matteo
P.S: mi risulta che le batterie gel siano poco adatte per l'avviamento
Buona ricarica
matteo
Grazie Matteo,
stasera le faccio la radiografia ahahahahaha
so che non e' adatta, ma per quest'anno abbiamo gia' dato!!Smile l'anno prossimo 2 belle batterie nuove!!!
[quote]svo75 ha scritto:
CUT
Silvio ma perche' non metti quella a gel per i servizi e quella ad acido per l'avviamento?
Cmq il coso della Sterling e' fenomenale, io sono rinato quando l'ho messo. Anzi, quando me l'ha messo il capo! Smile
Divertitevi!
h
Ciao Hiro,
La gel e' vecchia mentre l'altra e' nuova...... se uso la gel sui servizi ho paura di 'fonderla' con il frigo....... mentre sul motore 'sforza' meno e mi fa stare piu' tranquillo.
L'anno prossimo 2 belle batterie nuove!!
e tu tutto ok?? Violetta sta bene??
Citazione:svo75 ha scritto:
Ciao Hiro,
Vecchia ? Se va e gli amper sono corretti che problemi ti fai ? Se per sfiga dovessi aver problemi se sempre in tempo ad invertirle ? Tutto sommato e' meglio avere la garanzia che il motore parta che aver il frigo che raffredda Big Grin
  Quanto dura una batteria AGM ? rema 8 537 26-01-2026, 22:12
  Batteria LiFePO4 economiche su Aliexpress fontma 14 757 18-01-2026, 11:12
  Batteria lifepo4 e salpa ancora colibrìbis 16 1.272 06-10-2025, 10:09
  Conferma quale batteria motore acquistare rebzone 23 3.321 06-09-2025, 07:12
  Batteria, come trattarla nella sosta invernale di 7 mesi? Horatio Nelson 14 1.437 20-07-2025, 18:07
  Dispersione circuito batteria motore TeoV 13 2.954 01-07-2025, 07:23
  Controlli Batteria Litio giorgio8596 25 5.710 19-05-2025, 14:10
  Falso allarme carica batteria claudio.labarbera 4 841 17-04-2025, 17:55
  Scelta carica batteria claudio.labarbera 6 1.173 11-04-2025, 09:29
  ricarica batteria fuoribordo scarroccio 4 878 08-04-2025, 09:25
  Combinatori di batteria Cyrix claudio.labarbera 14 1.595 07-04-2025, 19:44
  Come collegare alternatore e batteria lifepo4 da 200A kobold 8 1.458 07-08-2024, 07:47
  scelta batteria grafosna 16 2.544 24-07-2024, 14:54
  Sostituzione batteria Ocean Signal Epirb1 Suncharm 24 4.044 08-07-2024, 23:08
  Allarme e spia batteria Volvo D2 55 su Bavaria kavokcinque 37 11.616 07-07-2024, 09:53
