Cambiare MMSI
devo cambiare il mio MMSI da un vhf portatile Retevis RM40 Marina Radio La retevis mi ha inviato le istruzioni che riporto
"Hello, Mario Alessandro Puppo
Thanks for contacting us. If you need to modify the MMSI code through software, it means you need a programming cable. We do not sell programming cables compatible with RM40 on Amazon. If you already have a programming cable, you can download the driver and software to your PC, and then use the software to modify the MMSI code. The modification steps are in the attached pictures. Connect the RM40 to the PC via the programming cable, and keep the radio powered on. Open the software. 1. Click COM port to select the correct port. 2. Click Clone - Read to read the settings of your own product. 3. Click Model to select the EUR version 4. Click DCS- Common, and then modify the self ID. Save the settings and disconnect the programming cable. The RM40 needs to be shut down and restarted before use. In addition, so that we can improve the quality of our products and better serve you, could you please tell us where and how you’re utilizing the walkie talkies and could you tell us which function of the walkie talkie do you think is the most important? Such as distance, light weight or durability, etc.? This is a huge help for us and helps us to make a better product for you. Thank you and have a nice day."
Ho chiesto delucidazioni circa il cavo di programmazione senza aver ancora risposta e tra gli accessori reperibili tramite il loro sito non ho individuato il connettore da usare allego la foto del connettore presente sul portatile, il diametro è 6mm, ci vorrebbe un cavo con questa spina e terminante con usb
Mario
Ex Resolution, ora Albachiara
La pagina del sito USA non promette bene:
mi manderanno il cavo per 15 euro per le spese di spedizione dalla Cina
Mario
  Furuno Radio Ocean 6800 AIS - MMSI katobleto 1 292 13-10-2025, 16:05
  Reset completo AIS650 Raytheon per cambio MMSI giulianotofani 20 8.083 25-07-2025, 09:35
  ST60 wind cambiare o provare a riparare ? tunnelrats 3 1.227 27-05-2024, 10:51
  Cambiare batterie con pannello solare Comet800 2 1.282 22-03-2024, 15:39
  Centri assistenza VHF iCOM per reset apparato (cambio MMSI) Furkenado 7 2.172 22-12-2023, 00:55
  lowrance lvr 250 E - reset mmsi giampiero 1 1.217 19-12-2023, 19:54
  VHF Icom 330 ge all'accensione togliere richiesta mmsi Wally 7 2.076 03-10-2023, 00:08
  Resettare mmsi vhf Danilo85 38 15.116 26-05-2023, 00:25
  Cambiare chiave d'avviamento UMdB 7 2.101 27-08-2022, 07:27
  MMSI e Matsutec hp-33a furietto 17 6.772 15-12-2021, 14:14
  AIS Icom MA 500TR cambio MMSI mhuir 3 2.418 02-03-2021, 23:57
  Modifica codice MMSI Link-8 TeoV 3 2.748 29-03-2018, 22:37
  Cambio MMSI su Standard Horizon GX 1500E danferra 2 2.681 29-03-2018, 16:48
  Cambiare o non cambiare le batterie? pollino2 9 2.573 01-06-2017, 18:22
  AIS cinese mmsi sarò in regola? gorbagliu 29 13.554 20-07-2016, 01:56
