le batterie più care sono le più convenienti?
le provocazioni,secondo me, fanno sempre bene e così,dopo l'interessantissimo post di Kermit sugli alternatori di potenza ho pensato di riportarvi,purtroppo non ho la pazienza di tradurlo,il pensiero del signor Sterling,quello della STERLING POWER regolatori etc. sull'argomento batterie con conclusioni che mi sembrano notevolmente diverse dai pareri di molto Adv che ho letto su varie discussioni.
<font face='Arial]What is the best battery to use for an auxiliary charging system?
I keep getting asked this question all the time, when being asked which is the best battery. I refer to marine or vehicle auxiliary charging batteries or domestic batteries. To say there is a lot of confusing literature about this subject would be the understatement of the year. The information in the literature tends to be correct, but it's the bits which are not in the literature and the customers' assumptions that cause the confusion and hence the problems. I will try to answer the question. But in order to save you time, I suggest you adopt the following attitude and make the person trying to sell you these things answer the questions below.
The key question
Another way to approach this subject is the simple Irish way (being Irish myself). I went onto the web and obtained 3 different battery type prices, these were the first prices I came to and have no reflection on any company. I was looking for about a 100 amp hour battery.
* 100 amp hour leisure. Normal open lead acid (so called leisure) £49.99
* 100 amp hour AGM = £175
* 100 amp hour Gel = £265.59
So in my simple mind the AGM is about 3 times more expensive than the standard one. And the Gel, about 5 times more. So the question is; if these batteries are 3 – 5 times more expensive than the standard one, what do they do that is 3 – 5 times better? Do they last 3 – 5 times longer? (I think not, more like the reverse). Do they charge 3 – 5 times faster to reduce your engine running hours? (Only in their dreams.) So rather than ask me weird questions; please ask the sales man, who is trying to sell this stuff for cycling, exactly what you are getting that is 3 – 5 times better than standard lead acid batteries. Then please let me know as I could do with a good laugh.
The brutal truth about marine leisure batteries
There is no such thing as a marine battery. If you see a marine label on a battery it is simply words and may as well say Mickey Mouse.
For cost and performance open lead acid batteries are king. All other batteries are a derivative of this, with variations to suit different markets, where there are specific problems implementing the standard lead acid battery. E.g. Gel, is a standard lead acid battery except that the acid has been transformed into gel. But by solidifying the electrolyte, you introduce many problems not associated with free flowing water based batteries.
“Most expensive is best” This is so not even close to being true. In fact I would say the reverse is true in the marine leisure market. When reading all the sales literature regarding Gel/AGM, please note that none of their curves and claims refer to standard lead acid batteries. (They know better). They never claim they have better performance than standard open lead acid, this is just an assumption on your side. They claim weird things including longer shelf life and that you can turn them upside down and have your dinner under them. Who cares? I want fast charging, long life, plus good value for money from my batteries. I don't want to sit and watch them on a shelf for a year and have my dinner under one.
If a statement says that this is the best battery. The question is, best at what aspect?
If the term 'maintenance free', is on a battery, then treat this with caution. There is no such thing as maintenance-free, all batteries are basically the same. A Gel, sealed lead acid and AGM are all only maintenance-free because of the reduced charging performance curves; and not because there is something special about the battery. If you charge a normal lead acid battery to the Gel or AGM curves, then they would not require maintenance either. Remember 'maintenance free' is a handicap to fast charging not an advantage. This feature, which on the surface looks good, is, in most cases the worst feature that you could possibly buy; as this feature dramatically limits the maximum charging characteristics of the battery.
Fast charging costs water, i.e. if you want to charge you batteries fast, don't touch a Sealed/Gel/AGM etc with a barge pole. Fast charging will result in a certain % water loss from the battery. If the battery is sealed the water loss cannot be replaced. REMEMBER FAST CHARGING AND SEALED/MAINTAINCE-FREE ARE A CONTRADICTION OF TERMS. You may not like this, but tough, it's the way it is.
Watch the term leisure / deep cycle as it simply does not exist. The standard, so called, leisure batteries, are simply starter batteries with extra support for the active lead material. This may increase the life by 5 – 10 %, but does not turn a starter battery into a deep cycle battery. True traction (deep cycle) are not available at a sensible price and are uneconomical to use for standard leisure use. However, if you plan to live onboard or travel the world then do look at 6 V or 2 V traction and build your battery bank up from those batteries, but expect to pay about 3 – 6 times the price of so called standard leisure batteries. On a daily use cycle, the standard so called leisure battery (which is a starter battery) will last you as little as 6 – 8 months whereas traction would last 15 years. But on a leisure rating (2 weekends per month and about 4 weeks’ holiday) then you would get about 5 – 7 years out of a standard leisure. That's if you charge it right using advanced regulators and constant current battery chargers).
Battery sales companies quote battery cycles such as 6000 cycles for the battery. This looks good on the surface, however it will be 6000 cycles at say 10% discharge. This is a meaningless figure. All batteries have a manufacturers' graph, which odds are, you will not see in full; as the embarrassing section tends to end up on the advertising company’s editing floor. The graph will have % discharge on one side and cycles on the other. This graph is sometimes shown on glossy battery information, but is normally censored at about 30 – 40% discharge, where the figures can still show 4000 cycles. What they fail to show is the 100% discharge cycle (which they of course say you should never go to and I am not for one moment suggesting you should). This, at the end of the day is the only ultimate datum point. Whichever battery performs the best at 100% discharge, will perform best at 50% etc. The interesting fact is that they are all about the same, that is, because they are all basically the same battery. A Gel and conventional starter battery go down the same production line until one has a gel substance put in it and the other liquid. The shock with this figure is that for Gel, Sealed, or leisure, etc, the constant figure is about 30 – 60 cycles, whereas true traction with thicker plates is over 300+. (However, don't expect to see this graph on glossy literature, as they are way too frightened of this graph and will not release it). It is however available from correctly specked commercial batteries.
So which is the best battery for standard domestic leisure use?
The job I am referring to is for auxiliary charging systems on boats, camper vans or vehicles. I am not getting into what each and every battery type is best at, or for; as each type has a market, it just maybe not this market.
To pick the best battery for your job, then at least understand how they work. Forget the actual chemical formula and all the fancy terms around. The bottom line is that lead acid batteries have been around since the 1st World War and the basic principles have changed very little since. The only thing we all agree on is that they are not environmentally friendly, but are cheap to make and will remain king until such time as someone comes up with a solution which can compete. Which by the way to date they simply have not. How do I know this? Well it’s very simple, if they had, the lead acid battery would be out the door so fast its toes would not touch the ground.
So how do they work?
Let’s understand the basics. They are all lead acid, but fall into 2 basic groups. A starter battery and a traction battery (fork lift truck, true deep cycle).
Type 1 (starter batteries). A battery is simply a bucket of energy. If you wish to get the energy out fast, to start an engine (cold cranking rating) then you need a large surface area (large plate size). The only way to get a large surface area into the bucket, is to make the plates thin, so they can squeeze into the bucket (this is your starter battery; it needs the cold cranking kick in order to start the car, so its plates are thin to achieve this). This theory is pushed even further with batteries which increase this surface area more, to make what are known as high torque batteries. These deliver even higher cold cranking, by putting the plates in a 'swiss roll' configuration, in order to make them thinner and increase the surface area. This is good for cold cranking, but has a fatal flaw when it comes to fast charging. (The problem is, it works too well when charging and destroys itself).
Type 2 (traction or fork lift truck batteries). These batteries are not interested in the cold cranking kick, which is required for a starter battery, but are still interested in the power in the bucket. So they can reduce their surface area of the plates. The good thing about being able to reduce the surface area is that you can make the plates much thicker. The end result is you still get the same power from the bucket it is simply delivered at a slower rate.
So, for deep cycle and long life, the traction batteries are by far and away the best. But their price tends to kill them. However, if you are doing a long journey around the world, or going away from the UK for 2 years plus, then investing in 2 volt or 6 volt traction batteries is a must, regardless of the cost. They will pay for themselves many times over. For general leisure use they are the best, but a bit of a waste of money, unless you intend keeping the boat for 15 years to get the use out of them.
So what's the end result of these two battery types?
A battery is made up of lead plates, with a lead paste on the plates. Every time the battery is used, then so many bits per sq inch fall off the plates, if you have a large surface area then a large number of bits will fall off. Then to make matters worse your paste is thin so you cannot afford to lose the paste. However, if you have a small surface area and thicker plates the same is true, but the plates are thicker and as such, you can afford to lose a small amount of paste. In a nutshell, that is it, or be it in very simplistic terms, those are the differences between traction batteries and starter batteries.
As you can see from the above 2 battery types, the plate configuration cannot be blended. If for starting, you have a large surface area of thin plates, for traction you have a small surface area of thicker plates. One is black and one is white, there is no grey area. So, if you are purchasing a battery and it has a cold cranking rating and the salesman says it is a deep cycle battery, but will also start your engine; then it is in fact a starter battery (end of story).
What we want now is the best for general leisure
Having understood the 2 basic types then you need to ask yourself: what do you want from the battery?
Most people want
* to charge their batteries as fast as possible in order to reduce their engine hours
* to pay as little as possible for the above
* to get about 5 – 7 years use as a leisure battery (2 weekends per month and about 4 weeks’ holiday per year).
If you are using your boat for leisure only, then stick to low cost lead acid so called leisure. If you want to turn your boat upside down for 5 seconds then the Lead Acid range with sealed removable caps would be a good choice.
If you want to turn you boat upside down for an hour or two then a Sealed Lead Acid would be worth looking at. However don't expect to charge them as fast.
Having had my so-called opinion published in a UK. boating magazine (boy, do Gel battery suppliers love me. I was taken off their Christmas card list), a Dutch magazine ran with it and the response was very good. The UK magazine did not follow up the article, however the Dutch magazine called ‘Zeilen' did. (The editor is Ruud Kattenberg.) They took the article and not only published it, but ran with it a lot of questions to their readers on their web page. They received over 500 responses and were able to confirm all my findings and published the results. (Not that I need any confirmation as we do this for a living, but it's always nice to have an independent source for folk who doubt you). Is this not what magazines are all about, trying to help the people who buy them and have a bit of a dialogue going?
Conclusion
The best battery to use for fast charging using advanced charging systems
* For general leisure use: use low cost Lead Acid which can be topped up with water. So called leisure batteries
* For long term cruising then use 6 volt traction
Avoid Gel / AGM for 3 reasons
1. very expensive
2. their fast charger rate causes them to gas
3. poor cycling numbers.
[color='Arial]
Secondo me è anche una filosofia commerciale, batterie buone potrebbero ridurre la necessità dei suoi prodotti; più o meno sono oggettive le differenze tra AGM/GEL e le acido.
Qualcuno sul mercatino ha venduto un ripartitore attivo perchè gli consumava il liquido delle sue batterie acideo troppo rapidamente e si era rotto i maroni di . scrivere a Sterling e chiedere cosa ne pensi lui !
Personalmente sono sempre stato un sostenitore delle batterie deep cycle per i servizi, mentre per le batterie di avviamento penso siano ok le spiroidali perchè hanno grosse correnti di spunto.
Sostanzialmente mi trovo abbastanza d'accordo sulle posizioni di Sterling
la conclusione è che a conti fatti , in un orizzonte temporale medio lungo (10anni), le gel non convengono dato che
bisogna modificare il ripartitore di carica e
per essere utilizzate al 100% necessitano di apposito caricabatteria ..
quindi la conversione vuol dire
costo batteria + costo modifica inpianto + caricabatterie nuovo = circa 6/7 batterie tradizionali
qualcuno potrebbe obiettare che funzionano bene anche con caricabatterie non specifici ... vero .. ma non durano 10 anni e 4000 cicli
domanda in 10 anni .. quante batterie usate
2 , 3 ..? ad arrivare a 6 o 7.. ce ne vuole
certo le agm e le gel sono meno sensibili a oscillazioni e ribaltamenti
e anno cicli vitali migliori ma il costo ...
mio consiglio per batterie strumenti , per chi vuole risparmiare :
esistono delle battetie tradizionali dette 'a lenta scarica' (o trazione leggera)
sono come le altre ma non hanno la corrente di spunto tipica per l'avviamento
le piastre sono piu sottili e garantiscono una più semplice carica/scarica , maggior longevità , e maggior numero di cicli (750?)e utilizzo in scarica profonda
non che un costo contenuto rispetto alla agm.
l'unico problema è nelle rivendite , che le fanno pagare molto più care di quello che valgono , per questioni di mercato
Mah.
A me pare che:
Il tratto seguente riporti dai sbagliati, anzi non ne riporti alcuno, si mischiano alcune verità con dati non supportati da nessuna citazione se non un 'fantomatico' dato di un produttore.
Oggi i grafici di confronto sono abbastanza pubblici, si vedono con precisione i rating di scarica e le potenzialità di cicli.
La questione è (secondo me) tutta qui: avevo anche postato un confronto dei costi in rapporto all'energia prelevata
Ovviamente, si può pensare che siano dati falsi o taroccati, ma anche il Sig Sterling non è mica uno stinco di santo...
Marco
Citazione:Battery sales companies quote battery cycles such as 6000 cycles for the battery. This looks good on the surface, however it will be 6000 cycles at say 10% discharge. This is a meaningless figure. All batteries have a manufacturers' graph, which odds are, you will not see in full; as the embarrassing section tends to end up on the advertising company’s editing floor. The graph will have % discharge on one side and cycles on the other. This graph is sometimes shown on glossy battery information, but is normally censored at about 30 – 40% discharge, where the figures can still show 4000 cycles. What they fail to show is the 100% discharge cycle (which they of course say you should never go to and I am not for one moment suggesting you should). This, at the end of the day is the only ultimate datum point. Whichever battery performs the best at 100% discharge, will perform best at 50% etc. The interesting fact is that they are all about the same, that is, because they are all basically the same battery. A Gel and conventional starter battery go down the same production line until one has a gel substance put in it and the other liquid. The shock with this figure is that for Gel, Sealed, or leisure, etc, the constant figure is about 30 – 60 cycles, whereas true traction with thicker plates is over 300+. (However, don't expect to see this graph on glossy literature, as they are way too frightened of this graph and will not release it). It is however available from correctly specked commercial batteries.
  Frigoboat e batterie AGM ste.fano 20 7.877 30-08-2026, 11:38
  Batterie IanSolo 824 1.113.871 29-08-2026, 14:54
  Stacca batterie sul negativo Osvi 7 1.744 14-12-2025, 21:02
  batterie ioni di sodio Tamata 2 833 17-09-2025, 15:19
  Aiuto su alternatore/batterie. Giurista 39 7.472 06-06-2025, 14:08
  Batterie Victron (piombo) innovative ... 22 7.707 23-05-2025, 20:35
  Pannelli e batterie Pepi 11 3.129 21-01-2025, 22:55
  Caricare le batterie al litio al 100% Canadese 22 6.706 07-11-2024, 14:35
  Cambiare batterie con pannello solare Comet800 2 1.737 22-03-2024, 15:39
  Morsetti batterie FIL 22 6.810 10-02-2024, 22:33
  Stacca Batterie Bavaria 30c MAXDV 0 1.079 02-02-2024, 08:53
  Vale prendere batterie AGM? UMdB 1 1.617 23-01-2024, 15:06
  Aggiungere delle batterie Servizi IlBlucaliffo 9 3.439 03-12-2023, 23:47
  Batterie elica di prua Salvatorecorradi 1 1.474 19-11-2023, 17:28
  Batterie sempre cariche scornaj 4 2.397 29-10-2023, 15:40
