A vela, marcia avanti/indietro/folle ?
sdagosx Offline
Nuovo Amico del forum
Registrato: Jun 2012 Online
Domanda che ai piu' forse risultera' banale. Qualche anno fa, ad un corso di vela, mi fu detto che con la propulsione a vela (e quindi a motore spento) era meglio lasciare il cambio in posizione 'marcia indietro'. Non ricordo la motivazione tecnica. Qualcuno sarebbe cosi' gentile di spiegarmela o di dirmi se la pensa diversamente ?
Grazie,
Sergio
06-06-2012 16:50
tetescio Offline
Registrato: Sep 2007 Online
ho un'elica bipala abbattibile,a vela metto sempre la retro,ma se mi chiedi perchè non lo so.vado a vela da 45 anni,mi hanno insegnato cosi e cosi faccioBig Grin
B.V.
Lorenzo
06-06-2012 17:03
N/A. Offline
Registrato: Oct 2010 Online
la Yanmar PRESCRIVE di lasciare in FOLLE pena la decadenza delle garanzie. e ho detto tuttto :
DATE February 8, 2008
TO: All Marine Distributors, Deale Sailing
SUBJECT: Gear in Neutral WhileODELS: All Sailboat Engines
We continue to get questions regarding the correct gear position while sailing with the engine OFF. This advisory is issued as a reminder; Yanmar requires that if sailing with the engine OFF (not running) the transmission shifter must be in the neutral position or internal damage to the gear or sail-drive will result. This damage will not be covered by Yanmar’s Limited Warranty. Please instruct customers and dealers who deliver the sailboat to the customer, of the correct (Neutral) position for the marine gear while ailing. If the customer desires that the propeller shaft not spin while sailing, either a folding propeller, shaft break, or other suitable device may be used. However, Yanmar accepts no responsibility for the selection, installation, or operation of such devices. Please also refer to Marine service advisory “MSA07-001_Yanmar Sail Drive Propeller Selection” for dditional information. If you have any questions regarding this advisory please contact a Customer Support epresentative at (770) 877- 9894.
06-06-2012 17:03
ghibli4 Offline
Registrato: Aug 2007 Online
Prova a leggere qua Questo contenuto non e' visualizzabile da te Ospite. Se vuoi vederlo, REGISTRATI QUI . Ovviamente se volevi sapere di un elica a pale fisse. Se abbattibile marcia indietro per bloccare il motore e permetterle di chiudersi. Per le orientabili non ho idea costano troppo Big Grin
(Questo messaggio è stato modificato l'ultima volta il: 06-06-2012 17:07 da ghibli4.)
06-06-2012 17:05
Frappettini Offline
ingranando la marcia indietro si impedisce la rotazione dell' elica trascinata dalla corrente d' acqua lungo lo scafo. IL tutto teso a minimizzare l' attrito dell' elica con conseguente freno al moto. Ci sono 2 scuole di pensiero al proposito: c'è chi dice che l' elica deve essere bloccata, c'è chi dice che l' elica deve essere lasciata libera girare. Il Basile, fece dei test su base misurata e notò che non si registravano differenze di velocità apprezzabili; a fronte di ciò, io tengo l' elica bloccata; se non altro evito degli attriti inutili.
06-06-2012 17:08
tiger86 Offline
serve per bloccare l'asse in modo che non giri e in più con alcuni tipi di elica sei più sicuro che si chiuda.
Leandro
06-06-2012 17:08
borascura Offline
Registrato: Apr 2012 Online
@Frappettini Ricordo bene il test. A conferma ricordo che quando un elicottero cade il pilota lascia l'elica libera che entrando in autocavitazione frena la caduta. Ergo frena di meno bloccata. Ergo con linea d'asse la marcia va tenuta inserita ( avanti o indietro poco importa io la metto indietro perchè mi intralcia meno il pozzetto ) se l'elica è fissa. Per le abbattibili sinceramente penso sia lo stesso ma non ne ho la piena certezza. Per i sail drive effettivamente se qualcosa forzasse l'elica fissa ( rete , cima, tronco d'albero ) il danno si riverberebbe molto violentemente sugli ingranaggi a 90° del piede decisamente diversi da quelli di un invertitore e sull'albero di diametro molto minore rispetto alla linea d'asse, quindi o il becco d'anatra o si decide se rischiare tra l'usura degli ingranaggi o la perdita della garanzia . Teniamo sempre presente che il sistema sail drive è una soluzione adottata dai cantieri per risparmiare sui costi di allestimento e sugli spazi e quindi inevitabilmente più fragile. A proposito passa dalla sezione saluti e baci che fra poco arriva Montecelio.
(Questo messaggio è stato modificato l'ultima volta il: 06-06-2012 18:04 da borascura.)
06-06-2012 17:48
rober Offline
Registrato: Feb 2010 Online
@pippuzzo anche VOLVO richiede sul sail drive elica in folle. La spiegazione di borascura è perfetta...poi ognuno si comporta come meglio crede...io infatti ho S.D. volvo ma su lunghe navigazioni a vela inserisco la marcia.
b.v.
06-06-2012 18:26
lupo planante Offline
Registrato: Nov 2007 Online
attaccaci l'alternatore e lasciala girare
06-06-2012 19:04
pomaggio Offline
Registrato: Nov 2011 Online
Salute a tutti.
mi intrometto anch'io anche se sono un 'novellino'. ma la discussione mi sta proprio divertendo, perche' da una semplicissima domanda e' veramente uscita la morale che la vela e' un' opinione (o oppppinione). Infatti, io non ho capito se e' meglio lasciare girare l'elica tenendo la folle per evitare attriti con l'acqua o se e' meglio tenere la marcia inserita per evitare attriti ed usura alla trasmissione dell'elica. per quanto riguarda l'elicottero, penso che l'elica sia lasciata libera per non fare girare la cabina dell'elicottero...e la cavitazione mi sembra un altro problema, da stabilire se e' maggiore in fase di motore acceso ed in marcia o in fase di motore in folle con andatura con le vele...le prescrizioni dei costruttori dei motori mi sembrano un'altra cosa ancora...
grazie
b.v.
06-06-2012 22:42
kawua75 Offline
Registrato: Jun 2010 Online
Citazione:pippuzzo ha scritto: la Yanmar PRESCRIVE di lasciare in FOLLE pena la decadenza delle garanzie. e ho detto tuttto
e come fanno a capire se la lasci in folle o in marcia?
07-06-2012 00:04
N/A. Offline
perdonami, io non sono la Yanmar, ho solo riferito ed inserito quanto sia Yanmar, ma anche Volvo dicono, poi per quella che è la mia esperienza ho smesso di mettere la retro il giorno che mi si è bloccato l'invertitore e c'è voluto l'intervento di Santa Rosalia per rimettere in ordine le cose. Come facciano a saperlo non lo so però se ti dicono di non farlo avranno pure un motivo...credo
07-06-2012 00:24
mckewoy Offline
Registrato: Oct 2009 Online
avete un'idea di quanti giri/minuti fa un elica a pale fisse con l'invertitore a folle??Big GrinBig GrinBig Grin
07-06-2012 00:54
kitegorico Offline
Registrato: Apr 2009 Online
Mah! Se fai una ricerca di discussioni sull'argomento ne escono un paio l'anno. Una la aprii colpevolmente senza prima cercare anche io, tempo fà.
Comunque la Volvo raccomanda espressamente sul libretto di tenere la marcia in folle durante la navigazione a vela anche sulla linea d'asse.
La spiegazione meccanica è stata data quì sul forum; ora non ricordo bene nè riesco a trovare la discussione, ma con l'elica bloccata dalla marcia ingranata e col motore spento sembra possa rompersi qualcosa di delicato presente nel motore (o nell'invertitore non ricordo).
Quindi direi che più che di scuole di pensiero, si tratta di scuole di progettazione dei motori (o degli invertitori).
PS. sul mio libretto inoltre la VOLVO raccomanda assolutamente di far girare l'elica a motore acceso e marcia ingranata per almeno un certo tempo dopo 10-12 ore di navigazione a vela! Il perchè credo che stia nella necessità di lubrificare qualcosa .....(?)
07-06-2012 00:56
Slam Offline
Registrato: Apr 2010 Online
La blocco anche per non sentire il fastidioso rumore di sottofondo, ma anche perchè penso che con il continuo girare a vuoto vada ad accorciare la vita dei componenti sull'asse.Smile
07-06-2012 01:41
JARIFE Offline
Volvo dice di tenere in folle con elica a pale fisse,retromarcia per eliche abbattibili o orientabili.(pag.21 manuale MD2010-2020-2030-2040)
Io ho provato con la due pale fissa e mettendo in folle la barca aumenta di uno zerovirgola,provate anche voi.Wink
dino73 Offline
Registrato: Mar 2008 Online
Forse dipende da che tipo di elica si monta. Con un'elica a pale orientabili, una volta in posizione a bandiera, gli attriti dovrebbero essere trascurabili (ed anche la rotazione dell'elica in folle). Quindi con elica tipo max-prop o j-prop dovrebbe essere abbastanza irrilevante. Che ne dite?
Dino.
07-06-2012 02:54
Blu Offline
Dino.
Penso che la tua elica, una volta disposta a a bandiera(e per farlo devei mettere retro) non farà più girare l'asse indipendentemente dal fatto che tu rimetta la folle. tanto vale lasciare retro.
07-06-2012 04:20
borascura Offline
Ohhh ragazziii non siamo mica qui per fare girare le palle dell'elicaaa.
(Questo messaggio è stato modificato l'ultima volta il: 07-06-2012 04:30 da borascura.)
07-06-2012 04:29
Montecelio Offline
Non sarà autorotazione?Wink
(Questo messaggio è stato modificato l'ultima volta il: 07-06-2012 04:37 da Montecelio.)
07-06-2012 04:36
  Fanta vela [vela ridotta con canestrelli sopra a genoa arrotolato] silverialessio 26 5.050 09-03-2022 09:56
  ho trovato questa vela nel set incluso nell'acquisto della barca "che vela e? olo 29 7.308 10-12-2018 10:21
  Albero ondeggia in avanti-indietro (Vaurien) Ander Tool 14 7.339 19-09-2014 12:01
Heart A vela con motore in retro (perchè non a folle?) Skipp 31 6.036 05-05-2010 04:08
