NAUTICAT - FI - Nauticat 351
Sgt.Pepper Offline
Registrato: Sep 2007 Online
Questa è la mia nuova "bambina" giunta il 12 agosto 2010. Chiunque volesse informazioni chieda e gli sarà risposto
un saluto
DIMENSIONS and CAPACITIES
CRAFT DESIGN CATEGORY:
Category A: This craft is designed to operate in winds that may exceed wind force 10 (Beaufort scale) and in significant wave heights of 7 m and above, and is largely self-sufficient. Abnormal conditions such as hurricanes are excluded. Such conditions may be encountered on extended voyages, for example across oceans, or inshore when unsheltered from the wind and waves for several hundred nautical miles.
This boat has been assessed using the Stability Index (STIX), which is a measure of the overall stability safety and considers the effects of boat length, displacement, hull proportions, stability characteristics and resistance to downflooding. This assessment has yielded the following data:
STIX = 32, reduce sail area when the wind speed exceeds 5 Bft.
GENERAL DIMENSIONS
L.O.A. 10.60 m 34'9"
L.W.L. 9.05 m 29'8"
Beam 3.50 m 11'6"
Draft in light craft condition 1.80 m 5'11"
The sink is 0.01 m / 187 kg
Ballast 2.7 tons 6700 lb.
Height of main mast over
waterline 15.5 m 50'10"
Sail area 75.0 m² 806 sq.ft.
Cruising range 500 miles at 7.0 knots with a
10% safety margin
Maximum speed Aprox. 8 knots
Shipping dimensions in cradle:
L.O.A 11.06 m
Length with bowsprit 11.30 m
Width 3.50 m
Serbatoio acqua: 450 l
Serbatoio gasolio: 335 l
ENGINE
Type Yanmar 4JH4
Engine output 39.6 kW(54 hp) / 3000 rpm
Cylinder volume 2.19 litres
Lubricants Please see the engine manual.
Consumo orario 3 l
In realtà la mia è questa ed è blu...ma per ora ho solo poche foto
PROPELLER AND SHAFT
Propeller Standard propeller 3-blade right-hand bronze propeller
Diameter 17"
Pitch 14"
Shaft
Material AISI 329
Diameter 35 mm
Cone or “taper” 1:10 ISO 4566
Cone length 75 mm
Flexible coupling
Type Centaflex AM28K-2.3-35
Stern gland
Bronze stern gland with tallow packing and greaser gun.
The greaser is located inside the aft cabin cupboard, where the fuel selector is.
Grease Shell Rodina Grease 2 or Unedo 2
Capacity Approx 250 g = 9 oz
Stern bearing
The bearing is installed in the propeller shaft bracket
Mark Countrose CRM 35
Type Water lubricated rubber bearing
Batteries 1 x 135 Ah start
2 x 180 Ah consumption
STEERING AND ENGINE CONTROLS
Steering pump (wheelhouse) Capillano 1250 V (5250)
Steering pump (cockpit) Capillano 1275 V (5274)
Rudder cylinder Teleflex BA 150-7 TM
Oil specification Automatic Transmission Oil Suffix A
Throttle and gear lever (wheelhouse) Morse MT3
Throttle and gear lever (cockpit) Vetus Sico
Engine room lever Ultraflex L232
WATERTANKS, SEPTICTANKS ETC.
Fuel tanks 325 litres in two tanks MDPE-polyethylene
- all of this capacity may not be usable according to trim and loading and a 20 % reserve should be kept
Water tanks 440 litres in two tanks MDPE-polyethylene
Septic tank 100 litres
BUIILDER’S PLATE
Part of the information is given on the builder’s plate affixed on the craft. A full explanation
of this information is given in the relevant sections of this manual.
MAXIMUM LOAD
The mass of a fully loaded Nauticat 351 is: 9600 kg
The maximum load of a Nauticat 351 is: 2100 kg
The mass of a Nauticat 351 in the light craft condition is 7500 kg
The maximum load consists of the following:
9 persons 675 kg
Basic equipment 80 kg
Consumable store, stores, equipment, etc. 1195 kg. Includes 325 litres of fuel 292.5 kg, 440 litres of water 440 kg.
Liferaft 50 kg
Full septic tank 100 kg
Cosa sono le leggi senza i costumi.
27-02-2011 17:05
r.spinadin Offline
Complimenti, un veliero stupendo e ricco di personalità...
Il tuo esemplare, anche se visto solo di prua, sembra particolarmente affascinante.
Ci hai già veleggiato?
27-02-2011 23:59
atnike Offline
Registrato: May 2010 Online
Congratulazioni!!
E' una favola....
28-02-2011 00:01
Sgt.Pepper Offline
Sono stato tutto il mese di settembre in Croazia e poi ogni due fine settimana, giretti in zona Porto San Giorgio
(Questo messaggio è stato modificato l'ultima volta il: 28-02-2011 01:40 da Sgt.Pepper.)
28-02-2011 00:14
miwiki Offline
Complimenti per la tua nuova 'bambina'.28
I migliori venti.
28-02-2011 03:49
mike59 Offline
:)veramente bella!. E gli interni da favola...COMPLIMENTI E BV
01-03-2011 21:55
anonimone Offline
Secondo me è GIOVINE dentro 42
Robiflinstone Offline
Un bellissimo motorsailer, complimenti!!!Smile
30-03-2011 23:38
matteo Offline
Registrato: Nov 2005 Online
Bellissima braca, complimenti
matteo
01-04-2011 22:55
dodo Offline
Bella e fascinosa come tutte le nordiche, con rifiniture al top e piene zeppe di sostanza, complimenti (quasi)concittadino Big Grin
04-04-2011 04:41
tatagata Offline
Registrato: Apr 2011 Online
Splendida. Finalmente una Barca con la B maiuscola.
Buon vento
22-04-2011 23:45
Sgt.Pepper Offline
Aggiungo un link di un minisito nel quale abbiamo in mente di inserire i diari di bordo delle nostre crociere. Con calma,....molta calmaSmile
un saluto
http://nauticat351.jimdo.com/
19-08-2012 16:24
teo4x4 Offline
Registrato: Dec 2010 Online
Complimenti per il sito e spratutto per la barcaTongueTongue
22-08-2012 02:58
  NAUTICAT - FI - Nauticat 33 skipperVELA 63 37.362 25-04-2025 03:17
