base albero sparcraft
Mariliero Offline
Registrato: Feb 2015 Online
Base albero sparcraft mai usata o installata (per misura sbagliata)
codice F460 F580 557403 (stampato sul pezzo, vedere foto allegata)
prezzo: 90 euro o miglior offerente! Ho trovato due link che descrivono il pordotto. Questo contenuto non e' visualizzabile da te Ospite. Se vuoi vederlo, REGISTRATI QUI . FM-460 Mast Step - Keel Mount: FM460-1K:
Adjustable Keel-mounted Mast Step for FM-460 Mast Section attaches to the keel or keelson with (4) 10mm (3/8") bolts in external slots to allow for precise positioning without unstepping the mast. Cast clear anodized Mast Step is 10 3/16" (260mm) long x 7 1/4" (185mm) wide, and allows for 25mm (1") fore and aft adjustment. Unit is marked 557403. 580,560E
Common Mast usage: Baltic 37, 38DP, 40; CT 556K mizzen; Beneteau First 40.7R, 41s5; Dehler 38, 39-1999; Dufour 41, 411; Emka 43*; Friendship 38S; Gib Sea 414; Grand Soleil 38; J/40*; FM-460 Mast Section
Jeanneau Sun-Fast 40, 42; JV 11M, 38*; Luffe 43, 46; Najad 360; Natascha 122K mizzen; Nissen 11.5M*, 12.5*; Omega 42*; Sigma 38; Stic 11.99M; Swan 36*; Sunbeam 39; Tartan 3500; Twin Peak 45K mizzen; Van de Stadt Winner 1120*, Forna 37*; Wauquiez 37; Westerly 36; X-412; Questo contenuto non e' visualizzabile da te Ospite. Se vuoi vederlo, REGISTRATI QUI . FM-580 Mast Step - Keel Mount: FM580-1K:
Adjustable Keel-mounted Mast Step for FM-580, F-560E and other Mast Sections, attaches to the keel or keelson with (4) 10mm (3/8") bolts in external slots to allow for precise positioning without unstepping the mast. Cast clear anodized Mast Step is 10 3/16" (260mm) long x 7 1/4" (185mm) wide, and allows for 25mm (1") fore and aft adjustment. Unit is marked 557403. Step is sometimes mounted on Deck, as with Catalina 34, 36, 387, and others. 460,560E Common Mast usage: Beneteau First 40.7C, 41s5*, 42s7; Catalina 387*, 400*; Cumulant 40/8 FD; Dehler 41*; Grand Soleil 42*, 43*, 45*; Island Packet 350; Kirie Feeling 416; Privilege 36; Tartan 3700;
Allegati
.jpg  base albero.jpg (Dimensione: 61,77 KB / Download: 224)
25-09-2020 23:57
skipperfelice Offline
RE: base albero sparcraft
mi candido come miglior offerente
01-10-2020 16:25
  Vang rigido Sparcraft Tatone 3 1.057 10-09-2019 14:20
  Base alluminio nemo per passerella fabrizio 61 0 548 05-10-2018 16:10
  Base nemo, con perno per passerella basculante fabrizio 61 1 580 26-07-2018 14:23
  Fiocco in dacron usato JL 16,15m base circa 5,50 sailyard 0 646 24-08-2017 09:15
  Spinnaker SL 9,70 base 6,40 200 Euro Marcox 4 2.014 23-12-2016 10:57
  Genoa mylar kevlar 12,10 m base 6,10 metri lellomusica 4 1.382 14-10-2016 22:46
  Tangone carbonio Sparcraft per 40 piedi claudio962 2 2.095 05-09-2016 15:30
  Boma Sparcraft 5,55 metri (E massima) Tatone 2 1.948 24-06-2016 09:43
  genoa inf.12,30 - bal.12,40 - base 6,70 carlo b. 4 1.440 26-02-2014 19:04
  vendo sparcraft made in usa seafox II 0 1.146 17-01-2014 03:38
