Pannello stereo per barche piccole
Rockdamned Offline
Registrato: Jan 2008 Online
Ciao a tutti,
vi segnalo, a Questo contenuto non e' visualizzabile da te Ospite. Se vuoi vederlo, REGISTRATI QUI . il lavoro di un italiano in quel di Svezia che si è costruito un sistema stereo a batteria per la barca niente male, praticamente una versione 2.0 del centotrucchi
Di seguito le sue istruzioni Smile spero torni utile a qualcuno, io non lo escludo questo inverno!
Citazione:I used:
- a Raspberry Pi (https://www.raspberrypi.org/)
More exactly a Raspberry Pi 3 Model B+, but other models can be used too. See the HiFiBerry Amp 2's specs for the supported platforms
- the amplifier for Raspberry Pi: HiFiBerry Amp 2
https://www.hifiberry.com/shop/boards/hifiberry-amp2/
- a pair of passive speakers. I reused the ones from my Marshall Stockwell that I forgot outside under the rain and that didn't work anymore.
https://www.amazon.com/Marshall-Stockwel...B016WA1V22
Here is a description on how to connect all together:
https://www.hifiberry.com/docs/projects/...udspeaker/
But I used the mediaplayer software Volumio, instead of HiFiBerryOS
https://volumio.org/volumio-overview/
Here is a guide on how to download and install the Volumio software
https://cdn.volumio.org/wp-content/uploa...umio-1.pdf
Actually it is all you need because you can control it via your phone
But I also added a 7″ touchscreen display for Raspberry Pi
https://www.raspberrypi.org/products/ras...h-display/
Here is how to use it with Volumio.
https://volumio.org/raspberry-pi-display...ic-player/
I used a cheap pine wood board that I cut using the cabin door as template, which I then painted with Wood stain Lacquer.
essebibi Offline
Registrato: Aug 2020 Online
RE: Pannello stereo per barche piccole
Bello, ma perché non una semplice autoradio?
06-07-2021 22:20
Rockdamned Offline
(06-07-2021 22:20)essebibi Ha scritto:  Bello, ma perché non una semplice autoradio?
vero, verissimo - ma vuoi mettere la componente nerd? 87
07-07-2021 19:41
penven Offline
Registrato: Aug 2011 Online
Apprezzo l'estro e la manualità ma perchè tutto quel lavoro quando oggi con il telefonino ottieni risultati superiori.
08-07-2021 09:33
essebibi Offline
(07-07-2021 19:41)Rockdamned Ha scritto:  vero, verissimo - ma vuoi mettere la componente nerd? 87
Dato che per lavoro faccio "l'informatico", quando salgo in barca voglio semplicità Smiley4
08-07-2021 21:34
SoulSurfer Offline
Registrato: May 2008 Online
io che sono malato di queste cavolate apprezzo, ma in termini di semplificazione (quel che manca non si rompe) preferisco sempre le 2 casse BT collegate al telefono o al massimo il semplice autoradio BT senza CD, ma con Usb (da 35€) in caso ciu fosse gia' un impianto "di serie"...
11-07-2021 18:56
Rockdamned Offline
(11-07-2021 18:56)SoulSurfer Ha scritto:  io che sono malato di queste cavolate apprezzo, ma in termini di semplificazione (quel che manca non si rompe) preferisco sempre le 2 casse BT collegate al telefono o al massimo il semplice autoradio BT senza CD, ma con Usb (da 35€) in caso ciu fosse gia' un impianto "di serie"...
agreed - però devo dire che l'idea di avere un sistema così geek e al contempo indipendente dal telefonino non è male - ha la sua batteria, il suo pannellino, sta lì, non ci pensi...
vabbe, poi io per quest'estate mi compro le casse bt 87
12-07-2021 12:59
Heart barche in Kit di montaggio Piac73 26 17.337 17-12-2023 21:16
  Come rendere facilmente amovibile un pannello BornFree 13 3.132 05-06-2019 14:01
  Materiali per manutenzione barche Claudio Rebuscini 1 2.078 28-06-2011 21:36
  Esistono dei demolitori per barche? asimov 19 11.481 01-11-2010 23:28
  Le barche della Tonnara Rurik 1 2.509 09-07-2009 09:57
  progettista interessante per barche veloci bistag 1 2.114 15-01-2009 18:51
