[Disc. divisa] Ipotesi problemi con Victron Phoenix ip43
mi aggiungo qui per chiedere se qualcuno ha avuto dei problemi con i caricabatterie Victron. Pare che una serie sia difettosa e verrà richiamata. Ora cerco il modello e lo posto
trovato! è il Victron Phoenix ip43.
Qui si puo trovare la discussione relativa .
Mai avuto problemi con l’IP43.
Comunque mi metterò lista per il field test della nuova versione.
(05-05-2021, 10:49)pepe1395 Ha scritto: Mai avuto problemi con l’IP43.
BV!
è un problema riconosciuto, forse meriterebbe un thread a parte, magari in una sezione richiami/prodotti difettosi o qualcosa del genere.
Riporto per tutti la risposta di Victron alla segnalazione del problema (piuttosto serio):
Hello all, what you're seeing (the start-up spike causing trips for MCBs) is indeed something from the design.
Not good!
The good news is that it works ok for the vast majority of installs. It depends on the MCB, its type, how often the MCB has already tripped / how easy it is to trip it, and so forth. But that doesn't really help you.
We've been working real hard on an improved design; and the good news is that production is now starting for it. It fixes above issue, as well as has a series of other improvements.
Once we have stock of the new units, we're keen to replace any products with this issue under warranty.
Tomorrow, I'll check when we have the first new units. To get yours replaced, two options:
go through your dealer, normal RMA process (except that you/your dealer/our repairs department must together make sure there is not just a same one shipped as a replacement - since that won't fix it)
participate in a small field trial. In case you're interested, pls put a small comment and I'll make sure you're contacted by e-mail.
All the best, and my apologies for this.
Matthijs / Victron Energy
Ps. another Phoenix IP43 charger related issue, its visualisation in Venus OS; is quite high up on the list to be solved as well. Its still months away I'm afraid - but not as far down the list as it was .
  Installatore Victron Pacio56 1 1.220 07-08-2026, 16:02
  Problemi sincronizzazione smartshunt acquafredda 6 622 14-07-2026, 11:47
  Configurazione Victron BMV-712 smart rebzone 94 22.052 12-06-2026, 14:20
  Problemi rinnovo licenza esercizio VHF Suncharm 10 1.730 14-05-2026, 17:05
  Victron DC-DC 12V 30A Wally 15 1.887 14-03-2026, 15:24
  Problemi su apparato cartografia Navionics miseno 0 1.026 28-02-2026, 17:05
  [Disc. divisa] Autohelm St 4000 come fare il reset 177117723 0 586 13-11-2025, 15:39
  Problemi Axiom con LightHouse 4.10.142 collegato a un AIS700 Magellan 5 821 18-10-2025, 23:42
  Problemi con NMEA 0183 Wi-Fi Gateway YDWN-02 Stranizzadamuri 23 2.142 01-10-2025, 19:25
  Sostituire Cristec CPS2 OEM 12V/25A con Victron Phoenix Smart IP43 12V / 30A (1+1) rveronico 19 2.174 01-09-2025, 20:36
  DST 810 con PaddleWheel Gen 2 con sporadici problemi AleSail 2 994 30-06-2025, 10:23
  Problemi connessione radar Quantum con Axiom tandu 15 3.715 03-06-2025, 16:22
  Problemi autohelm/raymarine 5000 plus> ev-200 ! bescafa 2 1.113 25-05-2025, 21:36
  Batterie Victron (piombo) innovative ... 22 7.953 23-05-2025, 20:35
  Victron Multiplus montaggio MikeM 5 1.649 14-05-2025, 07:44
