ho rifatto il motore + membrana s-drive
con un amico ho smontato il motore, ed abbiamo cambiato la membrana dell' s.drive.
[[hide][hide][hide][img]http://img229.imageshack.us/img229/5142/immagine031lt6.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/5142/immagine031lt6.f9b21e55f3.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/52/immagine070ey0.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/52/immagine070ey0.ad9fe63d0f.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4606/immagine083mq2.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4606/immagine083mq2.b43339574a.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4691/immagine086wv4.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4691/immagine086wv4.22db50418b.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/6348/immagine094za6.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/6348/immagine094za6.bac2c589c7.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img81.imageshack.us/img81/4111/immagine070dm5.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img81.imageshack.us/img81/4111/immagine070dm5.aff6b50301.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/1050/immagine080sf4.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/1050/immagine080sf4.4e93ab3697.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4756/immagine118sa3.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img142.imageshack.us/img142/4756/immagine118sa3.f1357427f9.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/4677/immagine119oz6.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img229.imageshack.us/img229/4677/immagine119oz6.5fbbc1a972.jpg[hide][img][/hide][/hide]
http://www.comet285.it
il sito dei Cometisti
abbiamo smontato, perchè abbiamo rifatto anche il motore, rettificato il cilindro, cambiato tutto.
Ottimo lavoro. Questi sono i velisti che mi piacciono. Quando vuoi una cosa fatta bene fattela da solo. Complimenti
le foto del cambio della membrana nel sito www.comet285.it
la volvo prima diceva 5 anni ora dice 7 anni io l'ho cambiata dopo 18 anni ho visionato quella vecchia, sembra nuova
Dall'ottimo servizio fotografico mi sembra che motore+invertitore+piede facciano corpo unico e quindi niente allineamento. Sui linea d'asse per esperienza l'asse va allineata alle boccole e poi motore+invertitore va allineato alla flangia dell'asse.
Grazie e buon vento
birimbao
Grazie e buon vento
birimbao
Scusatemi (capirete l'apprensione nel trattare questo argomento) mi sono fatto prender la mano ed ho tralasciato di salutare tutti gli amici del forum che mi sono subito dùstati di grande aiuto nel vedere quale fosse la procedura per la sostituzione.
Ciao a tutti!!!!!!!!!
nei lavori di carena eseguiti di recente non hosostituito la membrana che è lì da 8 anni circa, e pensare che avevo deciso di cambiarla il prossimo anno ede invece va a finire che devo farlo subito......
ecco perchè sto cercando di capire dalla esperienza altrui se questo trafile è un segno premonitore da prendere immediatamente in esame o se posso almeno passare l'estate. Considera che nel verificare questo trafilo ho notato la rottura del silentblock è l'ho già sostituito poi ho messo in moto il motore per un paio d'ore provando anche ad innestare la marcia in avanti ed indietro
Ciao e grazie
ti ringrazio per l'invito alla riflessione, in effetti credo proprio che il silent abbia prodotto 'l'anticipato' invecchiamento...
allora approfitto sai darmi indicativamente cosa è necessario cambiare?? solo l'anello od anche qualche o-ring ? ed inoltre avendo avuto difficoltà a rintracciarlo nella mia zona sai darmi l'idea del costo ? pgiacchè a Napoli telefonicamente nel giro di 1/2 ora mi hanno dato due prezzi uno il doppio dell'altro.
Grazie Ciao Luigi
Grazie Ciao Luigi
www.marinepartseurope.com/it/default.aspx
Saluti
dopo 10 ore di motore oggi ho tirato i bulloni della testa, e regolato le valvole
[[hide][hide][hide][img]http://img128.imageshack.us/img128/121/immagine255am7.jpg[hide][img][/hide][/hide]
[[hide][hide][hide][img]http://img128.imageshack.us/img128/121/immagine255am7.c8ac219fa0.jpg[hide][img][/hide][/hide]
  membrana sail drive - sostituzione Franco.tu 80 27.213 10-09-2026, 14:14
  Sail drive - quale rapporto dí riduzione? elan 333 7 1.293 14-03-2026, 16:37
  Sail drive: trattamento per ripristino parti esposte Markolone 1 516 05-11-2025, 14:39
  Problemi S-Drive Volvo 1230-SE ed elica Kiwi VICTOR47 6 1.073 12-10-2025, 11:51
Sad Corrosione sail drive st00042 183 71.470 20-08-2025, 13:10
  Sail drive 100 volvo penta malfunzionamento ? 1Andrea 9 2.160 07-06-2025, 07:43
  Olio Sail Drive Volvo Penta 130s - problemi con livello thebaron 13 3.320 29-04-2025, 22:51
  Sostituzione presa a mare piede sail drive Horatio Nelson 15 4.042 08-11-2024, 19:35
  Sail Drive Yanmar - valvola bloccata andante 69 22.794 21-05-2024, 14:37
  Olio S Drive scuro traballi carlo 9 3.229 21-02-2024, 17:47
  Sostituzione membrana saildrive zona BAT freedomblu 4 2.011 20-02-2024, 23:12
  s-drive sd 50 ed elica tripala fissa velista1210 9 3.190 18-01-2024, 13:09
  Taglia cime sail drive Pierpa01 3 2.079 18-12-2023, 17:24
  Sostituzione membrana saildrive zona Savona mac222 20 5.447 01-12-2023, 16:45
  problema motore volvo p. md 2020 anno 2005 ore motore 1200 pignieri 15 5.290 13-11-2023, 16:07
