Stazza imbarcazione
Salve,sono nuovo del forum,vorrei delle delucidazioni sul modo corretto nel fare il dislocamento a secco. Uno stazzature della fiv dopo la pesata mi ha detratto il peso del motore fuoribordo;preciso che e'l'unico motore (non e'ausiliario)dell'imbarcazione,inoltre nell'algoritmo del calcolo del Rating risulta penalizzante.
A me sembra una sciocchezza,vorrei delle precisazioni in merito.grazie.
benvenuto a bordo
Benvenuto.
Immagino, dato che si parla di pesata, che si tratti di un certificato IRC endorsed.
Se è così, basta leggere il regolamento:
Code. 17 BOAT WEIGHT
17.1 Boat Weight is measured in the following measurement condition:
17.1.1 Dry.
17.1.2 Fully rigged with all spars (including spinnaker pole(s) and jockey pole (if any)), standing rigging, backstay, running backstays and checkstays, halyards, mainsail and mizzen sheets, and vang(s).
17.1.3 Main engine installed, or outboard engine aboard in stowed position.
17.1.4 Batteries and fitted berth cushions on board in their normal positions if carried while
racing. These items will be noted on the boat’s certificate.
17.1.5 All permanent fixtures and fittings and items of accommodation whether detachable or not, including washboards, bunk and floorboards and saloon table (if fitted for racing) on board in their normal positions.
17.1.6 Standard fit out if rated to class standard data.
17.2 The following items shall not be on board for measurement condition:
17.2.1 Sails, headsail and spinnaker sheets and spinnaker guys, spare standing rigging and running rigging.
17.2.2 Fuel, water, variable ballast and the contents of any other tanks. Gas bottles shall be removed.
17.2.3 Food, cooking and catering utensils.
17.2.4 Anchors, chains, warps, mooring lines and fenders.
17.2.5 Clothing, bedding and personal effects.
17.2.6 All removable safety equipment.
17.2.7 Tools and spare parts.
17.2.8 Loose gear.
17.2.9 Portable electronic equipment not permanently attached to the boat.
Come si legge chiaramente il fuoribordo va stivato nel posto in cui sarà tenuto in regata ed il suo peso compreso in quello della barca.
Bacio Grazie Albert,
hai confermato le mie perplessità,
considera che lo stazzature Fiv e' stato anche pagato!!!
  Doppio segno di stazza ghibli4 5 2.556 13-06-2022, 14:27
  stazza della randa capatosta 6 2.923 21-12-2021, 13:01
  Come ottenere Certificato di stazza e quale categoria scegliere per Salona 45 lelez86 23 8.575 14-12-2021, 18:15
  Peso imbarcazione licenza navigazione Vs manuale costruttore kavokcinque 17 5.749 03-10-2020, 12:43
Information Stazza per il 2020 - IMS / ORC cavallone 3 2.644 08-05-2020, 18:09
  il code0 cambia misure di stazza ZK 49 14.561 06-02-2020, 22:20
Lightbulb Stazza per il 2020 IRC cavallone 4 2.591 08-01-2020, 22:19
  Certificato di Stazza e ORC andre082 3 3.864 14-10-2019, 16:12
Information Stazza per il 2019 - IMS / ORC cavallone 19 6.596 29-01-2019, 10:43
Lightbulb Stazza per il 2018 - IMS / ORC cavallone 1 2.781 16-01-2018, 20:31
  stazza luca boetti 8 3.768 09-09-2017, 19:29
  IRC o ORC ...Quale stazza per iniziare con regate d'altura Moulinex 18 10.134 31-03-2017, 21:35
  Ottimizzatori/Pessimizzatori stazza ulpiano 14 4.669 06-02-2017, 17:27
Lightbulb Stazza Regolamento IRC (tradotto italiano) cavallone 8 4.477 25-01-2017, 09:46
  Flusso attorno imbarcazione a vela di bolina einstein 5 3.316 09-12-2016, 19:42
