50 piedi con chiglia basculante
felix Offline
Registrato: Jun 2005 Online
Messaggio: #61
RE: 50 piedi con chiglia basculante
A first in yachting: the carrousel !
The swing keel and the turning live cell gives great power to the boat. Racers are well aware that any weight to windward can provide additional speed and this basic principle has been incorporated intelligently in the design:
The heavy parts of the rotating living space (chart table, galley, batteries, and hydraulics) can be canted to starboard or port using 2 rams under a central panel, similar to my living space on Paprec Virbac 2.
The 3 tonne bulb is transferred with just one finger using a hydraulic ram reminiscent of those that have already proved their worth in gnarly conditions.
This power also results in good seakeeping, because the boat is less likely to heel.
You can also reduce draught when anchoring with 3.5 m at sea for high-performance and 2.5 m near the coast. By canting the keel 50 degrees to port and positioning the living pod to starboard, the boat becomes level again. This is wonderful for entering shallow creeks and harbours and is a symbol of how smart technology can be used in cruising!
19-09-2014 19:28
Registrato: Apr 2007 Online
Messaggio: #62
(19-09-2014 19:28)felix Ha scritto:  You can also reduce draught when anchoring with 3.5 m at sea for high-performance and 2.5 m near the coast. By canting the keel 50 degrees to port and positioning the living pod to starboard, the boat becomes level again. This is wonderful for entering shallow creeks and harbours and is a symbol of how smart technology can be used in cruising!
Geniale!!!
20-09-2014 20:46
scornaj Offline
Registrato: Jan 2010 Online
Messaggio: #63
Beh bisognerebbe fare il confronto fra il peso del frigo riempito da mia moglie (verdure) e quello riempito da me ( grana e vino bianco) :-)
20-09-2014 21:08
lupo planante Offline
Registrato: Nov 2007 Online
Messaggio: #64
Geniale!!!
che in italiano...
20-09-2014 22:09
N/A Offline
Registrato: Feb 2010 Online
Messaggio: #65
(18-09-2014 16:54)bistag Ha scritto:  se volete sognare c'è anche questa che è un pò più lunga e non ha la canting keel (solo lifting) ma ha il wing mast e poi l'ha progettata Finot!!!!
http://www.oursonrapide.com/home.php
http://www.bernard-gallay.com/yacht-for-...RAPIDE-250
Questa non la conoscevo.....somiglia tantissimo al cigale
21-09-2014 08:17
Klaus Offline
Registrato: Jan 2008 Online
Messaggio: #66
Geniale!!!
che in italiano...
Se alzi la chiglia di 50 gradi a destra e metti la giostra a sinistra dovresti pescare 2.5 metri e quindi entri in parecchi posti.
Un difetto della chiglia basculante m'è stato raccontato oggi mentre eravamo in falchetta su un bordo di bolina alla Coppa Italia (in realtà io c'ho le zampe dentro, facendo il randologo... :89Smile.
Cippa Lippa ha sempre il generatore acceso, perché per regolarla di continuo ci vuole energia, quindi deve caricare un mare di nafta ed avere il sottofondo musicale continuo... Sadsmiley
Henry Ford
21-09-2014 22:00
N/A Offline
Messaggio: #67
Devono fare i serbatoi nafta tipo ballast
21-09-2014 23:05
albert Offline
Registrato: Jun 2008 Online
Messaggio: #68
(21-09-2014 22:00)Klaus Ha scritto:  Cippa Lippa ha sempre il generatore acceso, perché per regolarla di continuo ci vuole energia, quindi deve caricare un mare di nafta ed avere il sottofondo musicale continuo... Sadsmiley
Ormai, salvo che sulle barche coi coffegrinder (TP52), il generatore va per fare andare i winches, a meno di non avere la barca ripiena di batterie, che pesano più di generatore e gasolio e comunque vanno caricate ogni tanto.... canting generator o canting accumulators Smiley2...questo è il dilemma....
22-09-2014 09:12
Messaggio: #69
Io farei pompare l'idraulica dai grinder ..che ci stanno a fare sennò in barca?? Tipo CA "hydro hydro hydro!!!"
22-09-2014 11:05
Nimbo Offline
Messaggio: #70
Si ma ci vuole la macchinetta del caffe'!!! E in crociera la signora non apprezza.... Wink
Inviato dal mio GT-I9105P utilizzando Tapatalk
Matteo
22-09-2014 11:10
Messaggio: #71
mhmm... io parlavo di grinder ma non sono ragazzotti tanto semplici da portare in vacanza, quelli magnano!
22-09-2014 11:19
Nimbo Offline
Messaggio: #72
E quelli alla signora, immagino, non dispiacciano.... Smile
Matteo
22-09-2014 11:39
Klaus Offline
Messaggio: #73
(22-09-2014 11:39)Nimbo Ha scritto:  E quelli alla signora, immagino, non dispiacciano.... Smile
Mi hai ricordato un episodio. Ero a passeggio con due amiche per il centro di Roma quando abbiamo incontrato parte della nazionale di rugby italiana (Sergio Parisse, i fratelli Bergamasco e, mi pare, Bertolussi).
Cascò loro la mandibola e, dopo che erano passati, si sono guardate e una all'altra "Ma hai visto quanta roba ?!" Blinksmiley
Poi, per riprendersi con me, mi chiesero chi fossero quei tizi in tuta azzurra "Calciatori?" e io "See, je piacerebbe ai pallonari, st'adoni sò rugbisti!" 898989
Henry Ford
22-09-2014 15:05
felix Offline
Messaggio: #74
Geniale!!!
che in italiano...
Puoi anche ridurre il pescaggio all'ancoraggio, con 3,5 metri di pescaggio per alte prestazioni e 2,5 in prossimità della costa. Inclinando la chiglia 50 gradi a sinistra e ruotando la cellula living a dritta, la barca si livella.
E eccellente per accedere ad ancoraggi poco profondi e porti ed è un segnale di quanto intelligentemente la tecnologia possa essere utilizzata in crociera.
23-09-2014 01:06
N/A Offline
Messaggio: #75
Comunque, ritornando sull'ordo rapido da 60 piedi, trattasi di barca one off appartenuta/ente ad un italiano. Chi ha maggiori info?
23-09-2014 07:05
bistag Offline
Registrato: Feb 2006 Online
Messaggio: #76
Testa assomiglia al Cigale perchè ha lo stesso padre: Finot.
e sul sito puoi vedere un pò di filosofia progettuale:
http://www.finot-conq.com/en/content/ourson-rapide
Buon Vento!
Giovanni
Think harder.....remember who you are....
23-09-2014 11:42
  Chiglia Pogo 44 kavokcinque 39 4.963 03-09-2023 19:38
  [Disc. divisa] stondatura attacco scafo-chiglia marcofailla 16 2.684 24-02-2019 19:26
  Spi e Gennaker di un 24 piedi su un 30 piedi? morenji 13 3.475 24-12-2016 10:45
  Fiocco avvolgibile 40 piedi. Dacron? scud 80 12.180 05-10-2016 19:02
  allungare boma 39 piedi è sensato? marloc 15 3.402 10-09-2016 08:55
  Terzaroli su 32 piedi: quali opzioni? palla5000 27 5.618 16-08-2016 19:01
  Finitura bordi uscita chiglia e timone LiberaMente 44 7.953 06-04-2016 21:03
  Perdere la chiglia tiger86 61 18.250 24-11-2015 19:22
  Coefficente albero vincoalto in chiglia Agostino Repici 7 2.754 23-08-2015 11:48
  paranco randa su 31 piedi BornFree 5 2.499 17-03-2014 15:02
