Navigatrix sistema operativo gratis per navigatori
Forse molti hanno già sentito parlare o utilizzato OpenCPM un programma che trasforma il pc in un chartplotter.
Ora qualcuno ha pensato bene di creare una vero e proprio sistema operativo (una distribuzione Linux) e quindi gratuito che comprende un insieme di programmi utili a chi va in barca.
Oltre ad OpenCPM comprende un programmi per inerfacciarsi e scaricare carte meteo, per leggere i dati da una scheda GPS, per leggere i files GRIB, calcolo delle maree, ecc.
Questo il link per altre informazioni o per scaricarlo: http://navigatrix.net/
Questi i programmi già installati:
- OpenCPN 2.5.0 Chartplotter and all the plug-ins available for Linux
- *new* Chart Converter and Calibration Utility. Make pictures from your paper charts, calibrate them and use them inside OpenCPN.
- zyGrib 5.0.6 Weather Data
- GnuAIS Decoder 0.2.0 integrated into OpenCPN. Turns your old VHF into a fully functional AIS reciever
- PolarCOM 1.7.0 Full Screen GPS Display
- Matrix Mariner 1.0beta3
- Airmail 3.4.062 for HAM and Sailmail with the latest frequency list and added zyGrib support
- JWX 2.5 and HamFAX 0.8.1 to receive Weather Fax
- JNX 1.4 Navtex Decoder
- *new* JTides 5.2 Worldwide Tidal Calculator with the latest tide definition files
- WXTide 4.7
- XTide 2.11-1
- Astronomical Almanac 0.9.5-2 beta
- flDigi 3.21.36 and jPSKMail 1.4 to send and receive eMails over SSB without a Pactor Modem
- gpsd 2.95-12 supports many GPS receivers out of the box and needs no additional drivers
- gpsbabel 1.4.2 converts your GPS routes and waypoints to many different formats
- gpstrans 0.41 communicates with your garmin GPS receiver
- wvdial 1.60.3 ready to connect and use your Iridium Satellite Phone
- Stellarium 0.10.4 complete Planetarium for your actual GPS Location
- *new* Google Earth shows satellite images from the whole world
- hdparm 9.15 will turn off your hard drive temporarily while you run Navigatrix from a USB Stick or a Memory Card. This gives you full protection against permanent hard disk damage due engine vibrations and boat movement while under sail.
- redshift 1.5 sets the color temperature according to the position of the sun, click the red light bulb to activate nightvision for all applications, the color will change smoothly to allow your eyes to slowly adapt
- Calibre 0.8.23 Electronic Library ready to connect your eBook reader and convert/transfer all the books you like
- Easy to setup Full Live System Encryption. So nobody gets your sensitive data if you loose your USB Memory.
- wine-1.3.31 ... runs Windows Programs too! So you may also install your commercial navigation applications for windows (e.g. visual passage planner runs without a problem, just start the setup using wine and install it as you would in windows)
- *new* DSP enabled Kernel 3.0.9-dsp so you can use all the included SSB tools and OpenCPN with sound support which usually wont run under newer Ubuntu versions
- Capcode 0.9.5-2 beta, go to the terminal, enter 'sudo /etc/init.d/gpsd stop && capcode' and give it a try
- Free online support
- and many more useful tools for Videos, Music, Pictures, Word Documents, Spreadsheets, Web-browsing, Email, Internet Telephony and Data Rescue....
NavigaTRIX, ma che l'ha scritto TRIXarc?Big Grin
Big GrinBig GrinBig Grin
PS . Bel lavoro, complimenti!
Scusami,
Mi puoi per favore spiegare meglio cosa fà di preciso che io non riesco a capir bene?
Non fà già queste cose openCPN?
grazie e buon vento
Bello, anch'io ho un pc portatile vecchiotto con Ubuntu con installati parte di quei programmi.
Quello che potrebbe essere interessante sapere è se la distribuzione navigatrix è stabile e se ci fanno aggiornamenti.
Ubuntu è ormai una distribuzione collaudata, facile da adoperare e, per noi 'non troppo pratici', è una tranquillità in più.
Per conto mio è interessante. Da seguire
E' pieno di programmi in versione Beta!Sadsmiley
Credo anch'io che l'idea alla base sia buona ma la distribuzione non è ancora molto stabile.
L'ho segnalato perchè comunque credo possa essere utile seguire l'evoluzione e prendere spunto dai programmi installati.
La stessa cosa si può fare oviamente con qualsiasi altra distribuzione linux. Il vantaggio qui è che si trovano i programmi già installati e configurati.
Claudio
Claudio
e non è poco!
Citazione:perez ha scritto:
Scusami,
grazie e buon vento
grazie mille delle tante spiegazioni
ooooooo....
In linux e' quasi tutto e sempre in versione beta. Non significa che non funzionino Smile
Io l'ho appena installato su un vecchio thin client della Hp al quale ho messo una CF da 32 Gb come Hdd primario, e fin quì tutto bene, poi, quando ho cercato di far vedere a Opencpn il mio Garmin USB18, per chi non lo conosce è un'antennino gps con attacco USB, non c'è stato verso di farlo andare. Eppure su un altro pc dove ho winzozz e Opencpn, funziona alla grande!
Quelcuno può darmi una mano? le ho provate tutte....
Massimo Rossi
http://skipperone.it
Claudio mi sa che arrivi un po' in ritardo. ...
Ho sempre una chiavetta con Navigatrix ovunque . si sa mai.. :-)
Si può navigare per un giorno, no? E' tutto lì: un giorno dopo l'altro. (cit)
  Elan 340 - sistema 220V da banchina st00042 4 623 03-06-2025, 15:35
  Sistema di navigazione plotter ORCA AndreaP 0 579 30-11-2024, 10:03
  Sistema d'allarme (contro i furti) claudio.labarbera 13 3.397 14-12-2023, 18:26
  Blocco Pompa sistema distribuzione acqua dolce claudio.labarbera 14 3.304 07-08-2023, 22:34
  Progetto sistema di monitoraggio DIMMIBOX giorgino 18 3.632 14-03-2023, 00:33
  Opencpn maison gratis e opencpn dave register a 10 euro ghega 13 5.035 21-10-2021, 18:01
Question Consiglio per sistema videosorveglianza IP67 con GSM per barca Sikander 7 4.870 20-10-2021, 08:46
Question ghiaccio in barca con sistema 12 volt Sikander 1 1.776 10-08-2021, 08:45
  Pannelli FV: sistema per arco inclinabile e supporto pannelli [disc. unita] bellatrix 13 4.066 03-05-2021, 22:35
  Chiedo parere tecnico sul sistema di ricarica delle batterie(motore e servizi) kevlar69 12 4.066 17-03-2021, 21:09
  Secondo voi, quanto è il rendimento di un sistema ad accumulo ? maema 14 3.987 27-04-2020, 00:05
  Sail Grib WR interfacciato con sistema Tacktick m4ur0 0 1.198 05-01-2020, 22:12
  display generico NMEA 2000 per sistema GARMIN marloc 4 2.253 22-05-2019, 07:59
  NAVIGATRIX corradino 83 34.634 07-03-2018, 10:44
  Raymarine ST290 Sistema di navigazione roberto lavorini 5 3.000 24-06-2017, 16:06
