Discussioni: 78
Registrato: Jan 2011
11-11-2013, 18:20
(Questo messaggio è stato modificato l'ultima volta il: 11-11-2013, 19:14 da francesco72.)
Colibrì, ti ho mandato una mail. Intanto quelli di Seymo, che leggono il forum, mi hanno detto che, loro malgrado, sono obbligati a 'file a lawsuit against you and decide justice'. Ma cosa ho commesso di illegale se non testare un loro prodotto regolarmente acquistato? Le foto dei millefori parlano eloquentemente del loro prodotto. Mah ...
Discussioni: 776
Registrato: Mar 2010
11-11-2013, 20:01
(Questo messaggio è stato modificato l'ultima volta il: 11-11-2013, 20:07 da umeghu.)
You should explain to the SEYMO management that NO LAWSUIT can be planted against the Forum or the Forum's partecipants.
There was only a deep and sustantiated discussion on malfunctions on some of SEYMO RAY GYROs; as a matter of fact 11 out of 12 Gyros were found with the same and dangerous defects. You also opened one unit (yours) and found what the inside elements were.
It would be nice to have a lasuit planted, so it would be possible to plant a counter lawsuit:
A) for attempting to the lives and health of EUROPEAN clients and
B) for selling in EUROPE a good not responding to what described in the advertising.
Also, the fact that the clients should bear all the costs for returning the product to the manufacturer and have an exchanged one back, is VERY questionable, as this action is due to a product fault and to the supplier's responsability.
For last, there could also be ground for a 'class action' against SEYMO.
In Italy one would talk about 'Hay's tail'.
It is though true that I wrote them tellling that the situation (faulty products sold over the internet) was damaging their image.
I also suggested them to inquire their purchasing/manufacturing/testing procedures as 11 products out of 12 make a very large Quality Assurance Problem - Non Compliance.
Discussioni: 78
Grazie a tutti per il supporto che interpreto come un affettuoso abbraccio. Le mie intenzioni sono chiare quindi non ho nulla da temere.
Piuttosto, questa sera, andró a ritirare il prototipo, Vorrei darlo a Colibri ma non riesco a mettermi in contatto. Maró ha fretta di averlo, ma per assemblarli ho bisogno di qualcuno che lo testi. Io non ho tempo. Chi si offre come beta tester e si prende la briga di darci l'ok o il ko? Offritevi solo se siete sicuri di poter fare il test a breve (meteo permettendo). Appena avró l'ok il tempo di avere i pezzi da Farnell (1 o 2 giorni) + 1 giorno per l'assemblaggio e spedisco.
Discussioni: 16
Registrato: Oct 2008
Ciao Francesco, come già detto in precedenza sono a disposizione per fare il test del nuovo gyro, ti ho inviato il mio recapito.
Purtroppo il meteo adesso non mi consente di fare prove, spero per il prossimo fine settimana.
Discussioni: 52
Registrato: Aug 2010
Ciao Francesco,
io purtroppo ho la barca in Sardegna e per problemi familiari non ho al momento possibilità di raggiungerla (mi è saltato anche il ponte di Tuttisanti).
Rimango comunque disponibile per l'acquisto del prodotto finito.
Discussioni: 81
Registrato: Sep 2008
Io lo potrei testare questo w.e., però ho bisogno di mare mosso per dare un responso valido, dato che il Seymo, una volta superato il problema del ritardo, và alla grande. La scorsa Domenica 3 Novembre, sono uscito con 30 nodi di scirocco (c'era una mareggiata a Sistiana che impediva alle barche di uscire per la Rilke), ho volutamente tenuto il pilota con le onde sia al giardinetto che al mascone e teneva la barca in modo eccellente.
Discussioni: 125
Registrato: Aug 2007
La fortuna ci assiste sull'Italia c'è una forte perturbazione potrai fare tutti i test
Io mi prenoto per l'acquisto
Ciao Br1
Discussioni: 78
12-11-2013, 05:58
(Questo messaggio è stato modificato l'ultima volta il: 12-11-2013, 06:04 da francesco72.)
Ok, domani spedisco a Colibrì. Ricordatevi, se non mi sentite più, di mandarmi le arance ... olè
Vi lascio un nuovo video:
http://www.youtube.com/watch?v=LB6yAgrw788
... anche questo non è male:
http://www.youtube.com/watch?v=NHCimcrKSXs
Discussioni: 45
Registrato: Mar 2008
Solidarietà a francesco72. Considera quanto scritto da umeghu, tutte considerazioni sacrosante.
Nel frattempo io aspetto a mandare indietro il mio, 70€ di spese di spedizione non sono poche.
Discussioni: 776
La causa non potrebbe che essere civile, quindi NADA NARANJOS.
Inoltre nel codice italiano esiste il reato di 'Causa temeraria' cioe' di cuase campate in aria, fatte sapendo che non esiste un fondamento, ma , appunto, fatte per altri scopi.
Tranqilo, Hombre!!
Discussioni: 78
13-11-2013, 01:27
(Questo messaggio è stato modificato l'ultima volta il: 13-11-2013, 05:15 da francesco72.)
@Colibrì, spedito stasera con DHL ... si monta con il filo verso il basso. Buon TEST e facci sapere presto.
[[hide][hide][hide][img]http://farm8.staticflickr.com/7412/10822902683_f5e125d129_c.jpg[hide][img][/hide][/hide]
Discussioni: 22
Registrato: Dec 2008
É piccolissimo! Fantastico, per installare il seymo ho dovuto tribolare mica poco.
Quanto é spesso?
F
Discussioni: 78
Penso al massimo un centimetro.
Discussioni: 10
Registrato: Sep 2007
devo essere sincero,il mio Seymo sembra funzionare bene,ma mi fido molto di più di quello ADV,se decidi di produrlo e venderlo sarei interessato!!!
B:V.
Lorenzo
Discussioni: 22
Ottimo, posso metterlo dietro i cuscini senza ammazzarmi...
Cavo lungo 2 metri, GRAZIE.
speriamo bene per il test.
F
Discussioni: 78
tetescio: la mia intenzione è dispedirlo a chi ne fa richiesta al costo vivo dei componenti e, forse (spero di no), dell'assemblaggio. In ogni caso, giusto per dare una soglia limite, non potrà mai costare più di 30 Euro ... a esagerare.
Discussioni: 191
Registrato: Jun 2009
Discussioni: 10
Grazie francesco,mi associo al grido di andante,fammi sapere l'esito della prova e considera come già fatta la mia richiesta  !
Viva ADV
B.V.
Lorenzo
Discussioni: 16
Oggi ho ricevuto il Gyro da Francesco e spero di provarlo anche domani stesso, altrimenti questo fine settimana.
Discussioni: 78
Se funziona il merito è tutto del mio amico Giampiero ( detto Pico non a caso)
