Come lo odio ! (Vireisti leggete)
SoulSurfer Offline
Nooo.. non il motore, giammai !
quel prodigio di arte povera nonostante sia una fonte inesauribile di grattacapi e' diventato mio amico, ci diamo del tu e ogni tanto mi trovo a parlarci...Smile
mi riferisco al Sig Nick della Le Feuvre maritime technologies (technologies di che??),unico referente in europa per quella marca,ma solo perche' gira i mercatini
per l'ennesima volta che gli chiedo un consiglio, su come risolvere un problema di errata carburazione, lui mi risponde che c'e' da cambiare tutto e che e' meglio se compro da lui...
questo lo scambio di mail:
Hallo Nick
My BVR is giving me some problems on its tillotson carb.
i've noticed that the carb is backfiring as soon as i open the throttle, this takes the engine to stall,with all the related problems..
i've spent an entire day finding the perfect idle,and now runs very smooth on idle (it starts at the first try, even when cold,without choke,weather it's quite hot here).
spark plug, wire, diaphragm have been changed 2 months ago (after 9 months of winter pause out of the water).
i suppose that the problem isn't related to ignition,in fact last year it runs flawlessy.
any ideas on which settings,for the high rpm, are needed to solve the problem?
thanks in advance
e questa e' la sua risposta:
check timing is ok, and you have a blue spark on a new plug £4 on the
tip only
if timing is out, probably wrong points gap or burnt, change £25
if you tried all that, then its a new carb. they were not designed to
last 30 years plus in salt air with salt fuel (breathes in by diffusion
- unstoppable)
in my experience a complete new carb kit £42 and professional 1 hour £30
overhaul and tuning session restores less than 50% of carbs over 10
years old. the rest leak or cough or just sound rough due i deduce to
unclearable airways corroding closed in the upper half
so its straightforward decision after making sure tuning, blocked jets
and diapram are ok, its the carn £165, last 2 left in stock this summer.
if you want send it here and i will spend an hour £30 plus postage plus
full kit £42 + return £10, but it will probably be fruitless from what
you say and you still need to get the new one extra cost.
postage Italy admin is £10 direct (not ebay), please paypal
sales@vireengines for next day posting to you.
if your points are not perfectly flat and shiny i would not risk another
important voyage with them and order at the same time, £25 no extra postage
Nick
e tutte le volte e' cosi'....
vorrei montare una pompa esterna per l'acqua,mi puoi consigliare sulla portata?'
'no,compra la girante originale da me perche' poi non funziona'
(poi funziona da Dio e la stessa modifica l'ho gia vista a 3 vire)
penso che il mio dynastarter sia alla frutta, mi puoi consigliare su un alternativa?'
'ho disponibili 2 unita' a 425 sterline l'una, non ci sono alternative'
(poi ho aperto il mio, pulito tutti i contatti e ha ricominciato a lavorare egregiamente)
ho una crepetta nella testata posso saldarla?'
'no non terrebbe, ti posso ritirare il tuo motore e valutartelo 100£ sull'acquisto di un altra unita' al costo di 1200£'
(la crepa e' stata saldata e nemmeno si vede)
non lo sopporto piu', e tutte le volte ci ricasco...
Tuttologo da Banchina
(Questo messaggio è stato modificato l'ultima volta il: 28-07-2010 21:55 da SoulSurfer.)
28-07-2010 21:52
Temasek Offline
Ciao Nicco
Prova a sentire Maximo
Lui vuol sostituire il suo Vire,
magari ti può essere utile per i pezzi di ricambio.
28-07-2010 22:02
SoulSurfer Offline
beppe e' bastato smontare/aprire il carburatore guardarlo un po' torvo e rimontarlo...
ripartito tutto alla grande (come sempre)...
maximo ha un 7 e non un 6...
grazie comunque
29-07-2010 03:17
maximo Offline
Avevo, ora non più ho comprato un lombardini diesel bicilindrico nuovo di pacca, basta vire.
Il mio l'ho regalato al cantiere dove ho acquistato la barca.
Se a qualcuno interessassero le guarnizioni del carburatore, le avevo trovate da questo tizio http://stores.ebay.it/small-plant-repair...ec0Q2em322 su ebay a 7€ di acquisto contro le 50€ chieste dal fenomeno di cui sopra.
Agnostico è chi pensa di non credere a niente e pretende
che gli altri credano a lui
29-07-2010 06:42
SoulSurfer Offline
AAARGHHHH... MALEDIZIONE!!
29-07-2010 19:10
Temasek Offline
Nicco
Se per caso in questo momento, covi desiderii di vendetta,
ti posso passare il nome della barca ed il N° di pontile.Wink
Big GrinBig GrinBig Grin
29-07-2010 20:45
  Odio quelle sgorature gialle sui masconi lapo 24 4.745 07-02-2012 22:57
  wc marino,ti odio! mikael 17 5.302 01-06-2010 18:30
