50 piedi con chiglia basculante
#61
A first in yachting: the carrousel !
The swing keel and the turning live cell gives great power to the boat. Racers are well aware that any weight to windward can provide additional speed and this basic principle has been incorporated intelligently in the design:
The heavy parts of the rotating living space (chart table, galley, batteries, and hydraulics) can be canted to starboard or port using 2 rams under a central panel, similar to my living space on Paprec Virbac 2.
The 3 tonne bulb is transferred with just one finger using a hydraulic ram reminiscent of those that have already proved their worth in gnarly conditions.
This power also results in good seakeeping, because the boat is less likely to heel.
You can also reduce draught when anchoring with 3.5 m at sea for high-performance and 2.5 m near the coast. By canting the keel 50 degrees to port and positioning the living pod to starboard, the boat becomes level again. This is wonderful for entering shallow creeks and harbours and is a symbol of how smart technology can be used in cruising!
(19-09-2014, 19:28)felix Ha scritto: You can also reduce draught when anchoring with 3.5 m at sea for high-performance and 2.5 m near the coast. By canting the keel 50 degrees to port and positioning the living pod to starboard, the boat becomes level again. This is wonderful for entering shallow creeks and harbours and is a symbol of how smart technology can be used in cruising!
Geniale!!!
Beh bisognerebbe fare il confronto fra il peso del frigo riempito da mia moglie (verdure) e quello riempito da me ( grana e vino bianco) :-)
Geniale!!!
che in italiano...
(18-09-2014, 16:54)bistag Ha scritto: se volete sognare c'è anche questa che è un pò più lunga e non ha la canting keel (solo lifting) ma ha il wing mast e poi l'ha progettata Finot!!!!
http://www.oursonrapide.com/home.php
Questa non la . tantissimo al cigale
Geniale!!!
che in italiano...
Se alzi la chiglia di 50 gradi a destra e metti la giostra a sinistra dovresti pescare 2.5 metri e quindi entri in parecchi posti.
Un difetto della chiglia basculante m'è stato raccontato oggi mentre eravamo in falchetta su un bordo di bolina alla Coppa Italia (in realtà io c'ho le zampe dentro, facendo il randologo... 89).
Cippa Lippa ha sempre il generatore acceso, perché per regolarla di continuo ci vuole energia, quindi deve caricare un mare di nafta ed avere il sottofondo musicale continuo... Sadsmiley
Henry Ford
Devono fare i serbatoi nafta tipo ballast
(21-09-2014, 22:00)Klaus Ha scritto: Cippa Lippa ha sempre il generatore acceso, perché per regolarla di continuo ci vuole energia, quindi deve caricare un mare di nafta ed avere il sottofondo musicale continuo... Sadsmiley
Ormai, salvo che sulle barche coi coffegrinder (TP52), il generatore va per fare andare i winches, a meno di non avere la barca ripiena di batterie, che pesano più di generatore e gasolio e comunque vanno caricate ogni tanto...... canting generator o canting accumulators :. è il dilemma......
Io farei pompare l'idraulica dai grinder ..che ci stanno a fare sennò in barca?? Tipo CA "hydro hydro hydro!!!"
Si ma ci vuole la macchinetta del caffe'!!! E in crociera la signora non apprezza.... Wink
Inviato dal mio GT-I9105P utilizzando Tapatalk
Matteo
mhmm... io parlavo di grinder ma non sono belin tanto semplici da portare in vacanza, quelli magnano!
E quelli alla signora, immagino, non dispiacciano.... Smile
Matteo
(22-09-2014, 11:39)Nimbo Ha scritto: E quelli alla signora, immagino, non dispiacciano.... Smile
Mi hai ricordato un episodio. Ero a passeggio con due amiche per il centro di Roma quando abbiamo incontrato parte della nazionale di rugby italiana (Sergio Parisse, i fratelli Bergamasco e, mi pare, Bertolussi).
Cascò loro la mandibola e, dopo che erano passati, si sono guardate e una all'altra "Ma hai visto quanta roba ?!" Blinksmiley
Poi, per riprendersi con me, mi chiesero chi fossero quei tizi in tuta azzurra "Calciatori?" e io "See, je piacerebbe ai pallonari, st'adoni sò rugbisti!" 898989
Henry Ford
Geniale!!!
che in italiano...
Puoi anche ridurre il pescaggio all'ancoraggio, con 3,5 metri di pescaggio per alte prestazioni e 2,5 in prossimità della costa. Inclinando la chiglia 50 gradi a sinistra e ruotando la cellula living a dritta, la barca si livella.
E eccellente per accedere ad ancoraggi poco profondi e porti ed è un segnale di quanto intelligentemente la tecnologia possa essere utilizzata in crociera.
Comunque, ritornando sull'ordo rapido da 60 piedi, trattasi di barca one off appartenuta/ente ad un italiano. Chi ha maggiori info?
Testa assomiglia al Cigale perchè ha lo stesso padre: Finot.
e sul sito puoi vedere un pò di filosofia progettuale:
http://www.finot-conq.com/en/content/ourson-rapide
Buon Vento!
Giovanni
Think . who you are......
  Chiglia Pogo 44 kavokcinque 39 9.350 03-09-2023, 19:38
  [Disc. divisa] stondatura attacco scafo-chiglia marcofailla 16 4.796 24-02-2019, 19:26
  Spi e Gennaker di un 24 piedi su un 30 piedi? morenji 13 4.908 24-12-2016, 10:45
  Fiocco avvolgibile 40 piedi. Dacron? scud 80 20.404 05-10-2016, 19:02
  allungare boma 39 piedi è sensato? marloc 15 5.313 10-09-2016, 08:55
  Terzaroli su 32 piedi: quali opzioni? palla5000 27 8.837 16-08-2016, 19:01
  Finitura bordi uscita chiglia e timone LiberaMente 44 13.164 06-04-2016, 21:03
  Perdere la chiglia tiger86 61 23.213 24-11-2015, 19:22
  Coefficente albero vincoalto in chiglia Agostino Repici 7 3.675 23-08-2015, 11:48
  paranco randa su 31 piedi BornFree 5 3.117 17-03-2014, 15:02
  Modifica randa per un 50 piedi per un 38 piedi Mander 7 3.404 09-02-2014, 19:06
  chiglia a pescaggio ridotto bottadritta 13 12.309 11-11-2013, 22:22
  Deriva basculante ghibli4 32 9.396 13-09-2013, 00:04
  Manovra di approdo con barca a chiglia lunga skipperVELA 54 19.874 02-02-2013, 04:33
  deriva basculante o14 2 2.628 31-01-2013, 23:08
